slow mo Iso recording getting exposure and colours right
hylton
Member
Hi. using TC2, when I record slow-mo you get an ISO recording, so how do I record with the colours corrected so that what plays back meets the output?
Hi,
just to be sure -
The "Proc Amp" Settings within the Image Tap available on each Input MV window does not give you what you are looking for?
Hi Hylton,
TC2, as mentioned in your original post, should give you 8 MIX Outputs.
In your last post above you say you have only 4 MIX Outs, so my understanding is now you have a TC1 instead, correct?
Or indeed a TC2, but you will need all off the 8 MIXes of unit for your cameras (9) records and so?
Sorry, yes it has 8 mix out but I am using 1 mix out for program and 2 separate mixes for streams, leaves 5 mix out for replay.
But I haven't been using mixes for replay, it might be the soltuion I'm looking for. Il give it a try.
how many Input channels will you then end up for planned workflow?
Will the F1-F12 keyboard keys be enough when configuring your ´replay MIX Outs´ somewhere into INPUT 1-12 ?
If you will have more than 12 inputs I think you will have to create macro(s) for your automation for the MIX OUT replay clips recording channels starting from INPUT 13 and above (if you indeed have to/want to configure these MIX OUTs into switcher banks 2 or even 3).
Or you just use the (Instand) Replay) icon buttons options (under the PGM and PREV switcher rows) which will show up as soon you enable the ´Instand Replay´ Feature on the relevant MIX Outputs.
You can make macros to trigger replay on the MIX outputs. The command below will queue a replay into a DDR.
A value of 0 is MIX1, 1 is MIX2 and so on.
Back
Top
