JC53
New member
Hi All,
I could really use the community's help here... We are trying to get the LiveGraphics extension to work inside of Adobe After Effects. The "Allow Scripts to Write Files and Access Network" inside preferences is confirmed enabled. At present, when we pull up the extension "NewTek LiveGraphics Creator" inside of AE the extension panel is blank. This happens for the NewTek provided example comps and our comps as well.
Any pointers would be greatly appreciated!
TC-1 is running version: 8-0-230405
Premium Access version: 7-8-220107
Adobe After Effects version: 18.0.0 (Build 39)
I am aware that there are updated versions of AE. My system can not run them as it does not meet the minimum spec.
