Thank YOU Robert!
That looks so much better. See Image..
I am still getting a little more grain than I want. Any other suggestions?
Also check under the Effects panel->Processing and set the Dither Intensity to off.
-M
Render Globals Pannel, Shading samples will reduce noise caused by shading (blured reflections for example) Light samples will reduce noise caused by soft shadow lights (area, dome etc)
