DDR lag
DanielFrank
Member
I'm experiencing a rather annoying issue. When playing a DDR in program, the DDR is lagging / stuttering. It doesn't matter which DDR is playing. The problem is with all DDR's.
Also, Transcoding files in DDR is extremely slow.
Has anyone encountered this issue?
Performance: CPU around 20%, MEM 25%, NIC 108%.
Tricaster 2 Elite Build 8-1-230825 NDI Version 5.6.0.0
Hi DanielFrank,
Have you tried updating to the latest Software Version? Seems to have solved multiple DDR issues...
How about your drive capacities? Is there any external drive mounted and for any mistake chosen for replay (and transcoded to)?
Drives also loose speed when getting fuller than 50%... Should not be that problematic - just thinking...
Back
Top
