I have downloaded and installed the TC extension. When I try to connect to my Tricaster-Mini-X, I get a pop-up sign-in window asking for the Tricaster username and password. Where can I find or set that?
It's the LivePanel password, but I think you have to disable it to use the Chrome extension.
On the TriCaster go to the Admin screen (under the Shutdown button on the home screen). Then find Set LivePanel Password on the left side and uncheck this option.
you may want to check latest 8-4-250415 on this, if not already done yet.
Reading the Patch Notes of this release, I think there may be a fix on this included, but right now just a guess on my end without any futher ´testings´ here.
OK then, I thought It's something related also to the LivePanel pwd Kane mentioned above in this thread on this topic on which there is a Fix mentionen in 8-4-250415...
* Fixed an issue where LivePanel credentials were failing to save correctly in some situations.
