VizWorld Label Problem
Bill Schocke
New member
I'm having a peculiar problem where the labels I set up on my navigator maps won't show up after I save and re-open the scene:
The error in the Commands Window just says "error in plugin: CWMClient: can't find design for label ..."
Anyone have any ideas for what I might be doing wrong?
Hey Bill,
Could it be that you set a few CWMClient plugins with the same container for the label On-Map holder ?
or could it be that you set the same container as a On-Map Designs and to another CWMClient the same container as a On-Map Holder ?
Mike
erizos.tv
Hello,
As far as I know that means that the Object that label is looking at diesnt exist in your graphics hub, remeber that any styles you have on your tpl, you have to have in ur gh as an object
Hope that helps, good luck
Back
Top
