Large zoom in 12.1
Katrien De Roo
New member
Hi,
When using navigation from a large map (world)(M-S) to a country (D-1) container Map-Start switches off automatically. The only thing what helps, is choosing a less wide scale in M-S.
Is there a setting to fix this?
thx
Containers with NavFinders automatically turn off when it detects that the texture used on that container is of less quality than the coverage of the world tiles.. this is to make sure you always display the best quality textures based on your zoom level.. so this is not something that should worry you since is the expected behavior of the system
Back
Top
