changes in 3.6 might require changes in vizworld scene
adishin
Well-known member
For your info:
we have a scene with maps container resides under an Omo where the user can select a map as content for a specific area.
after upgrading to 3.6 all labels of those maps where loading on the center of the map rather where they should be.
Problem is due to Viz not calculating the bounding box for turned off objects.
solution was to place the map container in a group rather then directly under the Omo
attachment.php
Back
Top
