| Switcher Channels | 24 - 10 external, 6 internal, 8 M/E buses |
| Video Input | 8 simultaneous live video sources, in any combination of supported connection types, resolutions and frame rates (including PsF selections), with third-party video router support:
| Network Sources | 2 live inputs via Gigabit connection, selectable from any available network sources with support for video, audio and alpha channel:
| Robotic Camera Support | Access up to 8 live Pan-Tilt-Zoom (PTZ) robotic cameras via standard serial and network protocols, with preset system and user interface control over camera orientation, zoom, focus and iris |
| Media | 5 integrated digital media sources for video, graphics and sounds (2 DDRs, 2 GFX and Sound) + 15 buffers |
| Buffers | 15 content buffers to store and playback video, animations, still images and graphics:
| Mix/Effect Buses (M/E) | 8 freely configurable M/E channels with re-entry for video mixing, compositing, effects, real-time motion tracking and virtual sets, each supporting 4 independent Key layers, TransWarp effects, and Adobe® Photoshop® blending modes between layers:
| Macros | Record configurations and operation sequences, then attach to keyboard shortcuts, control surface actions, MIDI controllers, or on-screen hotspots for recall and automation:
| DSKs | 4 primary DSK channels, plus 4 additional Key layer per M/E bus, each with independent transition controls, 3D DVE, edge feathering, scaling, cropping and integrated TransWarp effects |
| Effects and Transitions | Integrated TransWarp effects engine on all effects channels supports standard transitions, customizable animation store transitions with audio, and overlay effects:
| Virtual Sets | 30+ HD live virtual sets, with presets, multiple camera angles, real-time reflections, and specular highlights:
| Holographic Live Virtual Sets | Support for custom virtual environments generated from panoramic smartphone, camera or DSLR images:
| Hotspots | Up to 8 freely configurable, interactive hotspots per input for macro control |
| Video Output | Configurable for up to 14 output connections, with support for key output and per-connection signal settings:
| Recording | Multi-track, multi-format recording of up to 8 simultaneous channels via IsoCorder™ technology:
| Recording Capacity | Includes 3TB internal drive and 3 removable 2TB media drives accommodating a total of ~220 hours 1080i (varies by resolution and format; capacity expandable using additional supported storage):
| Grab | Grab full resolution, de-fielded still images from all inputs and outputs, and freely choose to add grabs to Publish queue, Media Player presets and Buffer destinations |
| Media Publishing | Supports direct content upload to YouTube™, Facebook, Twitter™, FTP, local or external volumes, and network servers |
| Live Streaming | HD live streaming with simultaneous archive:
| Audio Inputs | 8 SDI Embedded 8 AES3/EBU 8 x 2 Balanced XLR (Mic/Line) Phantom Power Support |
| Audio Outputs | 3 SDI Embedded 2 AES3/EBU 4 Balanced XLR 4 Balanced XLR (AUX) 1 Stereo 1/4" (phones) |
| Audio Mixing | Integrated multi-channel audio mixer for internal and external audio sources, outputs, stream and headphones, with 4 fully independent stereo output mixes: 2 Master, 2 AUX:
| Supported Session Formats |
| Playback Media Formats | AVI, DV, DVCPro, DVCProHD, FLV, F4V, H.263, H.264, MOV, MKV, MJPEG, MPEG (1, 2, all profiles, program or transport streams), MP4, WMV, WebM, PSD, PNG, TGA, BMP, JPEG, EXR, RAW, TIF, AIFF, MP3, WAV, and more, with Import Media application for batch import with optional transcoding of files (including Apple ProRes) |
| Export Media Formats | Export media application for batch copying with optional transcoding of files to compatible formats for different applications and devices: Apple ProRes, AVI, DV, DVCPro, DVD, H.264, MOV, MPEG-2, MJPEG, MP4, WebM and more |
| Post Production |
| Monitoring | DVI monitor outputs for user interface and multiview preview displays:
| Signal Monitoring | Integrated Waveform and Vectorscope, full field rate with digital calibration, color preview and support for ITU-R Rec. 601 and 709 |
| Mirroring | Redundant operation and synchronized control supported between TriCaster 8000 systems connected to the same local network |
| Session Management | Setup and store session settings in reusable template sessions |
| Latency | Ultra-low, between 1 and 2 frames |
| Processing | Video: 4:4:4:4, 32-bit Floating Point Audio: 4 channels, 96 kHz, 32-bit Floating Point |
| A/V Standards | HD-SDI video conforms to SMPTE 292M SD video conforms to SMPTE 259M and ITU-R BT.656 Analog audio levels conform to SMPTE RP-155 |
| Control Surface | Includes TriCaster 8000 hardware control surface:
| MIDI Control | Support for standard MIDI protocol enabling third-party MIDI device control of TriCaster operations via macros |
| GPI Support | Supports 2 x 24 GPI signals via JLCooper eBOX GPI system |
| System Physical | 4U Rack Mount, with 550W redundant, removable power supply and multi-tiered hardware and software fail-safe:
