TC410 Plus with 460CS?
We are considering a purchase for a new TriCaster 410 Plus. Will our existing 460CS work with it (understanding that some key caps may be different)?
I sure hope so, because we barely have the budget for the 410 Plus. If it won't work, we may have to use it for non-TriCaster alternatives (which I REALLY don't want to do).
Please let me know if the TC410 Plus and 460CS are compatible.
-Sam
I have say I have found the TC 410 plus to be a rock solid performer. Money well spent.! .. not sure about the compatibility between 460CS…
Yes, the 460CS will operate exactly like a TC1SP when connected. Some of the buttons will perform different functions than what the 460CS label says. The image below shows the operational layout.
This image is super helpful for those of us with legacy hardware being used with AE3.
Do you know if there is an image like this available for the 860CS on AE3?
Awesome! Thanks so much.
Kind of a bummer they removed the transition controls for the 2nd (M/E) stripe of the panel. I guess its hard cuts all day for anything controlled by that stripe.
You can assign the transition block (t-bar, buttons) to the delegated M/E, by pressing the M/E button in the lower right corner of the panel. (Pressing Shift with this button will perform FTB).
Thanks for the tip. I guess i just got so used to the second stripe having its own transition buttons that I didn't consider the functionality got moved elsewhere.
Back
Top
