sessions are taking longer and longer to open
trebede
Member
My TC2 sessions are taking longer and longer to open (last firmware). The operation within each session is correct, but opening each one is getting slower and slower. It now takes almost 3 minutes to open any of them.
Can you think of what might be happening? Where would you start to look? I have checked that I don't have excessive content loaded on the DDR. We don't make recordings in Tricaster.
Thanks in advance for your help
Hi trebede,
Do you happen to have a network drive mapped and connected? If you do, would you mind disconnecting it temporarily, and trying to load the session again?
If not, can you clean up your session (by clearing out assets what you don't use on a file level - so in explorer), and create a copy of one, and see if it performs better?
Thanks @zmatula
I'm going to double check network drive mapped and see what happnes.
I did assets clean several times at file explorer level in eache sessions. Nothing has changed
Back
Top
