Replays Into DDR1
foxoirpires
New member
Hello. Im trying to create a macro where i can set a specific replay length (over the usual 10 seconds for Instant Replay) then populate it into DDR1 and play automatically. The issue i'm having is that each time it looks for a specific file path with a clip named something like Replay but each new replay would be named Replay (1) etc so it just fetches the initial recording. If i dont set a file path then the clip doesnt appear in DDR1.
Thanks
All you should do is controlling the value for replay_clip_duration, where the value should be a natural number (greater than 0). The number will reflect the length of the saved clip in seconds. :)
Hi zmatula. So the macro i have created uses replay_clip_duration but its only appears in DDR if a use record_and_chop. ive got a basic workaround but some of the clips are corrupted for no obvious reason. I have plenty of space in the drive so its not that.
Back
Top
