make my own ui
dibamd
New member
hello
Does anyone know how and on what platform it can be done with coding and without the need for additional software such as:
templatevizart or trio or ticker
Create a playback template for myself that works with the vizartist
sen
tankyou
I have designed for an scen at Artist
I want to make a software that the user can use during playback
I don't want to use templatevisard or other programs because I had problems using them
I want to make my own ui
it doesn't matter what environment you use to develop your control app.
what you should is to have an open network on the relevant port (normally 6100) and then find out which commands you should send when.
how to build this app is a complete world of decisions that starts with "what do you know?"
in these forums you can find answers for specific issues like how to change text, load image or start a scene.
good luck
good luck
Thank you for your support
Back
Top
