geronimofelizzola
New member
Good day, Forum VZRT team:
Greetings.
We are currently evaluating the purchase of a **TriCaster Mini S** system. For this solution, we have considered purchasing a tower-type hardware system (CPU), in which we wish to integrate a **Blackmagic DeckLink Quad 2** capture card, with the goal of having **8 SDI inputs for capturing video signals**.
In the available compatibility information, we see that it is compatible with the **DeckLink Duo 2**, which allows working with up to 4 input channels.
Therefore, we would appreciate it if you could confirm whether the **DeckLink Quad 2**, with its 8 channels, is compatible with the **TriCaster Mini S** software and if, with this configuration, it will be possible to simultaneously capture and process the **8 SDI video signals**.
Furthermore, we are also considering purchasing an **ASUS Dual GeForce RTX 5060 Ti** graphics card for this solution.
In this regard, we would appreciate confirmation as to whether this graphics card is compatible with the **TriCaster Mini S**, and if its use might cause any issues related to:
* Streaming and posting to social media.
* Compatibility with NVIDIA drivers.
* The proper functioning and stability of the TriCaster software.
We have attached images of the cards we are considering so you can verify the specific models.
Thank you in advance for your support and confirmation regarding the compatibility of these components before making a purchase.
We look forward to your feedback.
Sincerely,
Greetings.
Sincerely,
