Flex Headphone Jack
Hi TPUC,
I don't own a Flex Panel - so sorry for some guessing.
What kind of Headset/Phones do you use?
Have you tried different Phones?
Do you use a 3.5-6.3mm adaptor?
Is any of the used/converted Jacks a TRRS instead of a TRS Jack?
What is the impedance of your Phones?
Is your TriCaster Mixer setup: is the Phones Out mixer switched/linked to the Flex Out output?
Can you use the audio inputs inside the TriCaster?
What TC model do you have?
I did some testing.
TriCaster 8-1-230825 with Flex CS firmware v1.1-18-g48f7b0f works for audio output on the Flex.
When my TriCaster is updated to a version beyond that (8-3), I'm not getting audio from the Flex. I've entered a bug report on the problem.
Something you can try for now, is changing the Receive Mode in the Flex Web UI. Changing this setting to anything different, seems to kick the audio output active.
Kane I can't get the unit to do a firmware update, it gets to this point and hangs Copying image to rootfs.1 90%
There is a new update file for the Flex CS panel available for download. It's the same version number, but this new one is a 'full' install versus an 'update' install and will be accepted on the Flex CS.
That worked thanks so much. Now if they would turn on the HDMI port for a multiviewer it would be darn near perfect.
Back
Top
